STBD Sys Fault 194
Discussion in 'Engines, Drives, Props, etc.' started by Texas276, Sep 17, 2020.
  1. Texas276
    Texas276 New Member
    1
    0
    Sep 17, 2020
    Southlake, TX (76092)
    2009 Cobalt 276
    496 Mag - 375HP
    None
    Our 2009 Cobalt 276, 496 Mag - 375hp - Bravo 3 - was running across the lake at normal speed and all of a sudden it went into neutral and a constant alarm went off. Turned off power, turned of battery switch, restarted and it does not go into gear.
    The SmartCraft screen shows the following error - STBD Sys Fault 194 - A shift fault has occurred. Return to neutral. No matter what I tried it would no longer go into gear. We had the boat towed back to the slip and the next day I went out and tried again, starts and runs fine but does not go into gear. We have the DTS system so everything is digital and electronic. I cannot find any reference to this error code or what it means on the web. Looking for help
