Cobalt 240 in Citron Yellow - 2003 - This boat is very unique as it has been kept in a climate controlled garage for its tenure and it really shows. The pictures of the boat do not do the condition justice, must be seen in person to to be appreciated. The Cobalt 240 is a 23’ 9” bow rider that is coast guard rated for 11 people, which means plenty of room for the family and their friends. Further the storage in this boat is best in class and has the perfect storage location for all water toys or picnic items for a day on the water. The boat when introduced, won the US Powerboat magazines "Boat of the Year". https://www.tradeaboat.com.au/news-reviews/10157-cobalt-240-bowrider-review This vessel has been owned by two owners since new. The second and current owner took possession of this heavily optioned boat when it had 65.6 hours on the engine. The current hours are 415.6 hours and the boat has been utilized in fresh water, not salt. (Boat has two sets of keys and Cobalt Binder containing all system manuals) This 240 is optioned with the 5.7 GXI-320 HP from Volvo Penta and has the upgraded stainless steel counter-rotating dual propellers which make the boat very maneuverable. This motor option is arguably the best offered on the 240 as it is as fuel efficient yet performance oriented. The specification and options on the boat are as follows (From Cobalt); Style: Bowrider Centerline 23'9" (7.28 m) Beam 8'6" (2.62 m) Dry Weight 4240 lbs. (1923 kg) Deadrise 20 degrees Fuel Capacity 50 gal (189 L) Draft, Drive Up 18.25" (46 cm) Draft, Drive Down 37" (93 cm) Freeboard Forward 43" (1.09 cm) Freeboard Aft 38" (97 cm) Bridge Clearance 57" (1.45 m) Capacity, weight 1700 lbs. (771 kg) Capacity, persons 11 Trailer 2005 Galvanized LoadRite Roller twin axle trailer with surge brakes 23T5400TG1 with LED lighting and upgraded coiled wiring harness. Boat has been properly adjusted to the trailer and it pulls and tracks very well. Trailer was rinsed and has also been stored inside for life of trailer. The boat layout is optimal for families and very social. There is ample room up front for those that like to ride in the bow and plenty of seating in the main cabin area. Optional Bow filler cushions are included for both the bow and main cabin which you can use when lying in the sun. The large floor recessed built-in table is perfect for playing games or eating lunch/dinner. The water level swim deck with an extra-rugged, telescoping stainless-steel ladder makes for an excellent swim time for all ages off the back of the boat. The onboard head with light and fan is upgraded with a pump out which is very convenient. The built-in insulated cooler with upgraded LED lighting behind the helm seat keeps drinks and other food cold for the day. There is cavernous storage under all the seats, under the helm, and to either side of the engine. The starboard locker has a mesh container that will dry out wet lifejackets post water sports. This fresh-water only boat has been meticulously maintained and always stored in a climate controlled garage. Comes with Cobalt Manuals and Cobalt Manual Carry Bag. The layout established with the 240 was the benchmark. This is the nicest example of a 240 that I have seen and will be the most economical way to enjoy the quality/fit and finish of a Cobalt. I am happy to provide additional details and answer any questions that you may have, but serious inquiries only. **NO BROKERS** STANDARD EQUIPMENT Dash Accessory Power Plug - 12 volt In Dash Compass Depth & Water/Air Temp Gauge Package Hour Meter Wood Dash/Trim Package (NOT faded, looks new) Custom Wood and Leather Steering wheel with tilt Exterior Anchor Locker SS Bow Scuff Plate Stainless Concealed Boarding Ladder Midship Cleats Swim Platform Wet Locker with drain Transom Walk-Thru Interior Bow Walk-Thru with flush mount Bi-Fold Doors Cockpit Filler Cushions Stainless Cup Holders through out boat Floor Recessed Dinette Table Ice Chest with drain and upgraded LED lighting L-shaped lounge seating Wakeboard Storage Rack Starboard storage locker with integrated trash can In floor ski-locker with rubberized flooring and gas assist Structure/Safety/Performance Composite Transom Fiberglass Cockpit Liner Deck Fiberglass Stringer System Fire Extinguisher Ignition Safety Switch Kevlar Reinforced Hull Stainless Steel Windshield Braces Circuit breaker protected electronics Automatic bilge pump OPTIONAL EQUIPMENT Canvas Stainless Bimini Top with Sunbrella zippered cover Sunbrella Bow Tonneau (Yellow) Sunbrella Cockpit Tonneau (Yellow) Mooring Cover - Grey SharkSkin™ Dash Stereo Sony Head Unit AM-FM with Device Tray and removable faceplate Stereo Remote - dash Separate Main & Sub Amps Speakers - JL Audio bow/cabin Subwoofer - JL Audio Exterior Docking Lights - Stainless Steel Stainless Flush Mount Flagpole Mount and Flagpole Optional extended swim platform (removable) Upgraded Rivulet Swim Platform Carpet *NEW Extra set of carpet that can be installed by new owner Upgraded pop up LED bow light from Accon Stainless New Anchor Light Upgraded Stainless LED lighting under the swim platform Stainless Trim Tabs Interior Additional Accessory Power Plug - 12 volt behind captain chair Upgraded Rivulet Removable Carpet - cockpit/bow Upgraded Rivulet Aft Walk-Thru Carpet Bow Cushion Insert to make up forward sunning lounge Main Cabin cushion set for table area that makes an aft sunning lounge Optional Cockpit Heater utilizing motor block (Yes, this boat has a heater for fall boating!) Pump Out SaniPotti with upgraded holding tank and stainless pump out fixtures at bow Structure/Safety/Performance Battery Switch - Dual Forward Bow Upgraded stainless LED pin lights which are also installed in compartments Dual Batteries, one of which is brand new LED interior lighting Also Listed on The Hull Truth Link: https://www.thehulltruth.com/boats-...-yellow-fresh-water-garage-kept-must-see.html Boat is priced at $36,900.00
