496 Mag Engine Oil
Discussion in 'Engines, Drives, Props, etc.' started by Todd Seigel, Aug 1, 2017.
  1. Todd Seigel
    Todd Seigel New Member Founding Member
    8
    7
    Jul 24, 2017
    North Hudson, WI
    2008 Cobalt 302
    Twin Mercury 496 Mag Seacore
    Bayport Marina
    I'm running twin Mercruiser 496 Mag engines in my 302. What kind of oil and filters are people using in their big blocks? I am currently running AMS 10W-40, but am noticing lower oil pressure.
    On my old 2008 496 Mag I ran 4-cycle 25W-40 as Merc recommended and didn't have any issues.
    I have the PDF manual for the 496... drop me note at rob@boatingsuite.com if you want me to email you a copy.
  3. Walt P
    Volvo also recommends 25W40. My 8.1L runs about 45lbs of pressure at 3000 RPM. I use factory Volvo filters, and have had no issues.
  4. 3pointstar
    3pointstar Active Member Founding Member
    39
    35
    Granger, Indiana
    2000 -- 226
    7.4 MPI- 310hp
    GMC 2500 Durmax
    I go strictly/exactly what the Mercury manual says - nothing more and nothing less.
  5. Jevon Jamieson
    Jevon Jamieson Member Founding Member
    24
    10
    Jul 30, 2017
    Rogers, AR
    2013 Cobalt 242
    Volvo 6.0L 380hp
    2012 F150 Lariat 4x4
    I am really surprised at the 25w-40 selection. Sure seems really thick.
  6. 3pointstar
    39
    35
    Granger, Indiana
    2000 -- 226
    7.4 MPI- 310hp
    GMC 2500 Durmax
    Years ago - when we had 9 planets - we had a 165hp Mercruiser - straight 6. That engine was bullet proof. We had approximately 500 hours on it and I was driving it WOT for quite a while and it was very hot outside - 100F+. All of a sudden the oil light went on and I immediately shut the engine down - we let the engine cool - oil was full - restarted the engine and the oil light was still on. I took it to the marina thinking I blew the engine - come to find out the oil that we used since day 1 straight 30W Rotella had broken down - I was religious in changing the oil and filter - so it wasn't the lack of maintenance. The marina said that Mercury changed the viscosity to 25W-40 and this is what we should be running - We changed oil and the it ran without issue. We sold this boat when we purchased our Cobalt- I've been using the 25W-40 as specified within the owners manual - I figure the engineers know a heck a lot more than I what is best for the engine. We have 7.4MPI and per the owners manual - the engine - if run hard will use a little oil. Well this summer was the first time that we were able to really open this bad boy up for an extended period - and sure enough at the end of the day - at least 7 hours running it hard (it was on lake Michigan - which was like glass) - it used about 1/2 quart. We have a little north of 550 hours on the engine -
    Tonka Boater likes this.
